Adventures with BioDiesel
bbjordan
Snow Monkey
Ashern Manitoba
My son wanted to borrow the 1992 F-250 with the 7.3 IDI to haul his trailer of tools and materials to help a friend of his with some renovations on a rental property. No problem. I think the timing is about right from the trial and error method. Time to see how it performs with a little weight behind it. I filled the front tank and topped off the rear tank with the latest batch of B100 I got from my supplier and off he went. He pulled the trailer 325km at 120 kph with no problems. He pretty much used up the rear tank, about 65 liters. Thats 5km/l or 14 miles/imperial gallon. Not bad. After parking the trailer, he goes to move the truck to the front of the house. I get a call: "Hey dad, the truck won't start." Dohh! Good thing I gave him an extra fuel filter! :) After changing out the fuel filter, and a little bleed of the Schrader valve, the truck fires up. Yay! The truck gets moved to the front of the house and after a couple of beverages, he goes to leave. I get a call: "Hey dad, the truck won't start." After doing some simple tests, it looks like the Injection Pump. I know its probably not the injectors, because I just put a good set in less than a 1000 km ago. Its about midnight now, so I say leave it 'til morning, and I'll drive up with an IP. I want to drop off a couple of barrels of bio-diesel at the folks farm anyway, and its only about 50 min. further up the road.
I pack up a spare lift pump, IP and my tools and head up there. The truck still won't start after sitting the night. He even tried putting in 20 liters of petro-diesel in the rear tank. The IP is swapped out about an hour after I get there. After bleeding the lines, the truck fires right up. It sounds and runs great. Sometimes you just get lucky with the timing. When its hot just a touch of the key fires it right up. Awesome.
We use the truck to pick up supplies and go out for lunch. The truck is running great. I park it in back by the trailer.
We decide to take a big load to the dump with it. By now the truck has sat about 2 hours. No start. ***? I let it sit while I walk away in disgust. :backoff
We find some other work to do while I figure out what I'm going to do now. My son's friend says he has a buddy that is a diesel mechanic and we could tow it to his shop where we could have a look at it. Not bloody likely! No strange hands are going to touch my trucks. About another 2 hours go by, and I have to get something out of the truck so I figure I might as well try it again. It fires right up. Hmmm...puzzling, but it works for me. ;Sweet I'm thinking maybe heat soak? We load the truck up with garbage that would have taken him 3 loads in his van, and take it to the "Eco Station". There is a line-up and its wait and go for a while. I'm afraid to shut off the engine at this point. We get rid of the load and decide to get something to eat. I'm not going the leave the truck running the whole time we're in the restaurant, so I shut it off. When we come out after eating, it starts, but reluctantly. It took a couple of cranks. Not just a touch of the key. All good.
At this point I decide to head home. My son is going to stay another couple of days. So I fill both tanks on the truck before I go.
The day he is leaving, I get a call: "Hey dad, the truck won't start." I get another call about a half hour later. "I got it started." No problems the rest of the day. He is finally ready to leave at 8:00 pm. I get a call at 9:00 pm. He is on the highway home. "Hey dad, the truck is making a lot of white smoke." :eek: My heart sinks. Not another blown head gasket. That would make 3 in about a year!
"How's the temperature on the truck?" I ask.
"Its good." he says.
I told him to keep going and keep an eye on the temp gauge.
I get a call about an hour later. "Hey dad, its still smoking, but not so bad. The temp is good. Its actually running pretty good except for the white smoke."
Well thats good...
The truck makes it back.
I still had two barrels of biodiesel on my truck that I wanted to pump into my tidy tank. I normally pump it with my little pony pump 'til its almost empty, then pour the rest into a 5 gal. pail and pour that through a filter. When I poured the dregs of the last barrel into the pail I realized that it wasn't biodiesel. :eek: It was unprocessed, unfiltered Waste Vegetable Oil! Gack! It all comes clear now: the clogged filter, the no start, the white smoke.
I picked up 5 barrels of biodiesel. Three were in white plastic barrels, two in steel drums. I didn't notice the difference because I didn't see it until I emptied the last steel barrel which is what I used to fill the 1992 F-250.
So, my son brought the truck back, but it wouldn't start without a sniff of ether. If it was warm, it would start. I parked the truck behind my garage and prepared for the analysis of the damage the next day. The tailgate and bumper were covered with an oily mist.
Today I tried to see if it would start. No go. I bumped the timing up a little. No go. I swapped out the injectors with a set of "remanned" injectors.
No go. I set the timing back to were it was. It sputtered some. I took off the fuel filter and poured out the contents and filled it with known good biodiesel. Bing! it fired up.
BTW. The injectors that I pulled out need work. The first two that I pop tested wouldn't even pop!
So, lessons learned:
1. My 7.3 L engine doesn't like WVO.
2. My 7.3 L engine won't start with WVO when its cold.
3. WVO gunks up my injectors.
4. I always need to check every barrel of biodiesel I get.
5. I should get clear hoses for my pony pump.
6. Always carry a spare fuel filter. A spare lift pump is also a good idea.
7. I have so much respect for the IDI engine. :hail
8. Humans make mistakes. Ok, I already knew that one. :rolleyes:
Hey, the other IP might still be good.
There are probably more lessons here, but its late. Here's a picture for you guys:
From left to right,
The biodiesel I normally get.
The fuel that came out of the fuel filter.
The WVO that I mistakenly got.
subway
be nice to the admin :D
York PA
wow, the engine would have been fine if it was set up for it. stock you are right that was way to strong a mix. glad you got it going!
sounds like allot of work swapping out all those parts though, more of lifes lessons.
bbjordan
Snow Monkey
Ashern Manitoba
Fast forward 5 years...
It's been about 5 years since the bio-fuel debacle. I had originally posted this in the 6.9L IH & 7.3L IDI Diesels forum, but I should have put it here:
Got the '92 in the sig that has been sitting at the farm for at least a couple years. When I parked it out there it had bio-diesel in it. 100% in one tank if I recall correctly. Years later it has precipitated a dark red-brown goo. We discovered this after getting the truck running and driving it around the country block. Ran ok. Next day crank no start. Basic trouble shooting...Check if there is fuel. Yup. Check fuel filter.
Good grief!
With flash:
Without flash:
Replaced the filter. Truck started and ran. :)
My brother bought a car in Ft.Saskatchewan which is about 70 km from the farm. So, we filled the tanks with diesel and headed out in the truck. It started dyeing when letting up on the fuel pedal quickly. Rather annoying when you're heading into a left turn. We made it there.
I thought the truck seemed sluggish, so I advanced the timing a bit while my brother finalized the car deal. IIRC, I had retarded the timing to run with the bio-diesel.
It fired up ok, and seemed a bit better, but hardly noticeable. We made it home ok.
In the evening I got the idea to try the ATF in the fuel filter procedure...until I pulled the new filter off. It was worse than the first fuel filter!
That is why there are two bases in the picture. The dirtiest one is with only 140 km (87 miles) on it.
The truck would not start the next day, with a third fuel filter. :( Gummed up Injector Pump.
We spent the day replacing the IP and injectors and pumping the fuel tanks out. Got it done and took it out for a spin to warm it up.
Wow! Did that wake it up! Got back after a good run and timed it. 12* BTDC with the Ferret. Set it back down to just under 10* BTDC.
old IP:
New IP:
Yes, I had the parts with me. :sly I suspected this might happen. Especially after my brothers attempts at trying to start it.
The goo stays liquid in the fuel, but if exposed to air turns to a hard plastic. My brother thinks its polymerization happening. I recall reading something about bio-diesel doing that when exposed to oxygen and steel...like sitting in a vented fuel tank for years. :rolleyes:
When we pumped the tanks we ran it into a stainless steel pan. The goo stuck to the bottom of the pan really well, meaning it was a b!@tch to clean! I cleaned the filter bottom with gasoline. It kinda dissolved it, but only kinda. It was a pain cleaning it off.
End of report. Going to buy a lottery ticket, I seem to be on a lucky streak. :D
bbjordan
Snow Monkey
Ashern Manitoba
Pop tester gummed up
After 5 years, this still haunts me!
Today I figured I would pop test the injectors that came out of the truck in the previous post. It wouldn't build pressure even after I replaced the old biodiesel in the pop tester with fresh #2 diesel. Doh!
So I took it apart. Gak! The little square by the screwdriver is the screen from the hole on the right.
MTKirk
Billings, MT
The WVO in your sample jar looks horrible, that's not going to work in any vehicle. I've been running WVO successfully in my two diesels, the Ford is definitely more picky about fuel than the Benz. They key is to have CLEAN oil with water under 300ppm (I filter, settle, centrifuge, filter again). Also you Never want to send WVO to the injection pump until it's 140 degrees Fahrenheit. You also need to run the truck long enough on diesel to purge all WVO before shutdown, takes about 2 minutes in my truck.
bbjordan
Snow Monkey
Ashern Manitoba
Red Goop
I wonder why the fuel pump won't pull from the tank?
Good grief! A shot of the inside of the tank :eek::puke::
The first few scoops that I took out:
There must be over 300ml, close to !/2 quart.
bbjordan
Snow Monkey
Ashern Manitoba
I realize now that I was facing two different problems. The first problem was getting WVO instead of biodiesel. The second was the polymerization of the biodiesel. This occurs over time when you leave biodiesel in a metal container exposed to oxygen.
AcIdBuRn02ZTS
Indiana
And this is why I stick to petroleum based waste.. lol. What a mess! Good deal getting it sorted out.
Ramtough01
