I bought a 85 6.9 from a van to swap into a 84 f350. When I got the 85 the IP was removed, so I figured I was going to have to get it retimed. Then I read that as long as the gear cover isn't removed, it doesn't have to be retimed. The issue is when I put it on my stand and turned it upside down to check the main and rod bearings, I'm afraid the gear fell out of time. Does anybody know if there is enough room in the gear housing for the IP gear to come out of mesh and loose time?
My second question is is there any internal differences between a van and truck motor, or internal differences between an auto and a manual engine? I know I'll have to swap the manifolds and the flywheel and flex plate, but I'm hoping there isn't a internal vs external balancing issue.
My third question is on the van motor there are only nine flex plate bolts, and a space for a tenth that is not drilled. I haven't seen the truck motor to know if thats normal or not, so, is that normal?
Thank you all in advance for any insight you can provide.
