The 6.9 in my Bronco is an A-block. It has the typical external crack by the block heater. I need to get this fixed, but am not sure how to get it done. I thought the only way to fix it was by having tapered plugs installed. I talked to a friend today who says that you can have it welded, but a hole needs to be drilled past the end of the crack so it won't crack farther. Anyone have any opinions on which method might be better?
