Iirc, they mount in different.
My 94 PSD uses the IDI style radiator.
95 they went to a different design. Utilizes the degas bottle. It's a capless system.
Can't say for the BBF, I would imagine it's different.
Did you compare the 2?
A gasser one, no. They are more like the short, wide radiator similar to the older trucks you hear about....
If it was an 97 7.3 PSD, it should be the same size and shape, but by 97 Ford had eliminated the radiator cap and moved to the degas bottle setup. This all can be switched over to the IDI. @no mufflers is currently using this setup in his Bricknose.......
