94-98 Upgrade plan
sarrettblack
Cincinnati, OH
I have owned multiple diesel trucks, but know relatively little about performance parts so I was hoping to get some guidance. I plan on buying a 94-98 powerstroke and will initially have a performance part budget of $10k - $30k. After the initial budget I plan to continue purchasing more parts as needed. I am trying to determine what needs to be purchased and in what order. My primary goal is speed/acceleration. Very irregularly will I need to tow or haul anything relatively heavy. The truck would be 4wd and auto trans. The one thought I had was to purchase the transmission first since I will need it eventually and it is likely to be the most expensive purchase. Thoughts?
Mike_42
Kid Mechanic
Canton, MS
If you plan on dumping that much, get your trans built or rated for 5-600whp. I would start with air first, get a nice turbo setup going, 4" CAI, intake manifold? get a bigger DP/exhaust not sure on aftermarket headers. A solid tuner and then start on the fuel side.
threegenpowerstroke98
Canada
Check out swamps website. They have performance kits for the engine side. as for transmission. would do that first. Traction/ladder bars. If you're an 250 solid front axle swap. Either a dana 60 from a same year 350 or a coil sprung from an 05 up. Gearing may be something you want to look at too. go check out powerstrokearmy, still lots of guys going big with the 7.3s over there.
With that kind if money, I would buy a 99.5 to a 2002 F250 short bed SG cab. Put a tuner in it first, then see how fast and acceleration it has.
freqencyheight
