93 F250 gear ratio
EMD_DRIVER
Say what?!?!
Beaufort, SC
The door frame sticker on my 93 says Axle: C5. I learned that it's a 4.10 limited slip axle. Not knowing a whole lot about axles, I'd like to know if/how the front axle would work, when in 4WD.
Also... With the E4OD, what kind of RPM's should I be seeing around 70? Even after swapping solenoid packs, I still show 2,400RPM's at 70.
Thanks!
Gary
Diesel JD
Gainesville, FL
Check this rpm calculator http://ring-pinion.com 2400 is pretty high but at 70 without O/D when I had the C6 in there and the 4.10s I would be over 3000rpm, yeah I think I crossed the 3K mark at 68mph actually, so it could be, I don't know how deep the E4's overdrive is, but that calculator should tell you
reklund
Henderson, Nevada
That difference in RPM can be affected by tire size too... What size of rubber is on your truck?
Ryan
coletrain777
Clark, Missouri
235/85/16's are 31.73 inches tall.
An E4OD final gear ratio is .71
This means that at 70mph in overdrive you should be running 2158 rpms. Now of course the tire circumference will go down slightly because of the sidewall compressing under the weight of the truck, but this should get you close. I would think anything over 2250 either means that your tires are severly underinflated, your torque converter isn't locking up in overdrive, or your gears are something other than 4.10's. If you have 4.56's they would make your engine turn 2400 rpm's at 70 mph (sounds like maybe what you have). Anyway, there ya go!
The site I use for calculating tire height is:
www.wallaceracing.com/tire-aspect-calc.php
and the rpm calculator I use is:
www.csgnetwork.com/multirpmcalc.html
Hope that helps... Cole
160k87F250
not rocket science
York, PA
That would work if there was a direct connection between the trans and engine (I.E. manual trans), but there is a torque converter, and there is slippage with a torque converter. I bet there is a difference of rpm when you are going up a hill at 70 mph compared to coasting down a hill at 70 mph. With a manual transmission vehicle, the rpm stays constant with the vehicle speed. (Does that make sense?):dunno
John
zpd307
Zumbrota, MN
i have the e40d, 235/85 tires, and 3.55 gears. at 70 i am turning about 2050 rpms. at 2,000 i am at around 67/68 mph.
LCAM-01XA
my very own hell
235/85-16s here as well, 4.10 gears, 60 mph at 2000 rpms, 65 at 2150, and 70 at about 2300 if I remember correctly, but I usually keep it at 1900 rpm and 57 mph and get 20 mpg.
LCAM-01XA
my very own hell
lol, I stick to the right lane, only thing that can hurt me is a big rig and those actually move at just that speed during the day so we form a nice line. The small vehicles don't bother me, if they want to play chicken they're more than welcome to feel my half a foot thick and a foot and a half tall rear bumper and 2" solid-piece steel draw bar ;)
93 Farm Truck
