92 f250 TTB Front Lean
jay_t
Between the top of the passenger side tire and the bottom of the fender 6.5 inches.
On the driver side the same measurement is 7.5 inches.
Both front tires are the same size. The space between the bump stops and top of leafs are equal. If there were a problem with the leaf or bushings, they would be different, right?
Both front body mounts are the same height.
Where should I look to account for the difference?
More on the truck please. Not enough info. Do you have a lift kit in there or something done? Ball joints worn?
cpdenton
Truck needs paint.
Conway AR
Check the pivot bushings on each beam. Where they bolt to the brackets on the frame?
JunkCowboy
