'91 accessory for radio??
6.9poweredscout
Bleeds IH red...
Northeastern Pa
I have a '91 350 and the key wont turn on the radio when I cycle the key all the way back. Is that normal for a brick nose?
redneckaggie
rebel w/o a cause
angleton/stephenville tx
nope. I would say pop the radio out and see what kind of hacking has been done to the wires and which wire the po decided to use for remote trigger. or it is possible that the ignition switch on the bottom of the column isnt powering her up. but I can tell you that my 91 the only thing keyed on by rotating key back is radio.
LCAM-01XA
my very own hell
If you have power windows in that thing, they would power up too with the key in the ACC position. Use that to determine whether the problem is in the ignition switch or elsewhere. Since you didn't complain about no radio with
ignition in RUN position, I'd say the circuit between switch and radio itself is good, and the problem is most likely in the ignition switch itself.
redneckaggie
rebel w/o a cause
I would say to start at the ignition switch on the bottom of the column, could just be out of adjustment. It has two nuts and sits on studs with slotted holes so it can get out of adjustment from always pushing it forward to crank. when I did this I found it easiest to pull the fuse panel cover and the two trim pieces that sit on either side of where the column comes through. then drop the column by removing the two bolts on the clamp up next to the steering wheel. you could probably get to it without removing any of this but i hate being curled up in the floorboard trying to reach around everything
LCAM-01XA
my very own hell
^^^ What he said! ^^^
If the ignition switch appears factory looking and old, replace it for a peace of mind - they are a known vehicle fire starter, don't want your truck to go up in smoke.
TronDD
MA
What I did, was turn the key to ACC, hold the key in position and slide the switch down the column so it engages the detent (and starts trying to pull the key back into LOCK) then tighten up the nuts and make sure you can still start the truck.
Tim.
JunkCowboy
