91 7.3 Coolant Change
tdodd1125
Painesville/Ohio
New to the forums here and learning a lot, but got a 1991 F350 XLT Dually a few months back. Just recently got started on making the truck daily driver capable. Noticed that the PO had disconnected the heater core, so I decided to replace. Pulled the old core out no problems (It was horrible looking, so my suspicions were correct on that). My troubles however, started when I decided to change the coolant out, because of the new component. I was able to drain the radiator successfully with no problems. As for the block, I decided to start with the drivers side, because the passenger side looks a bit more difficult to take out. I took what I believe to be the drain plug out (brass plug with square end on the right hand side when facing the oil cooler). No coolant came out. I'm confused a bit, and the plugs on my truck look different from the pictures on the other threads about this topic. Any advice would be greatly appreciated. This thing has been nothing but a head ache for me recently.
tdodd1125
Painesville/Ohio
Actually, you're half right on that my friend. I started with the plug on the opposite side of the oil gallery plug. That was a dead end. Then I pulled the oil gallery plug and realized what it was. So still lost.
FORDF250HDXLT
Maine & Oklahoma
welcome to OBN and the joys of old idi trucks.don't worry,it'll get worse before it gets better.:D
tdodd1125
Painesville/Ohio
I'm going to try the old poke method tomorrow. Thanks for the welcome! I consider myself an "above average shade tree mechanic" haha. Let me tell you though, this diesel thing has definitely been a learning process. Heater core couldn't have been easier to remove though, way better than my 83 Continental.
madpogue
Madison, WI USA
Not that it's relevant here, but since your truck is not a Powerstroke, you might want to post in the IDI forum. (The block plugs happen to be in pretty-much the same locations on the PSD and IDI blocks.)
Big Bear
