So I was looking for driver/passenger cup holders to add to my '88 E250. Guess people didn't ever drink a pop while driving in '88. I wanted one like we had on our old E150 that was wooden and fit on top of the dog house. I found some but they were $70. So I decided I would make one.
Started with a 1x12
After cutting the right length I got out the hole saw. Figured 3.5" was good.
Test fit
Then I measured and cut the angle so it didn't take up too much room.
Test Fit.
Then I had to figure out how to mark and cut the other openings. I cut a template out of paper and then used chalk to do a rubbing.
I cut out the openings on the template and taped it to the cup holder board.
Did my best to trace the openings onto the cup holder board.
Then used my Dremel to cut it out. A jigsaw or scroll saw would have made a cleaner cut, but I don't have one and this is a budget project.
Checked the holes. Lined up okay. Gonna take some sanding to smooth out the openings.
Next I cut a piece of the 2x12 to support the bottom of the cups and used 2.25" pieces of dowel to connect the top and bottom. In the pic I just have zip ties supporting it to test fit it since the doghouse angles out.
And another angle.
Now I have to decide if it will be stained to match the wood grain on the dash or painted. I am leaning toward staining it. What do you think?
Started with a 1x12
Test fit
Test Fit.
And another angle.
