Jetman88
A couple of days ago i went to start my truck after work and found I made the rookie mistake of leaving the lights on and killed my batteries completely. Since then truck has a slow crank but drains the batteries faster then normal and creates a lot of heat (enough to make jumper cables start to glow). The truck already has the gear reduced starter which is still not too old and has worked great up to this point. My first thoughts were either a bad starter/solenoid, corroded cables, or bad batteries. I replaced the battery cables in hopes that better flow would help but it still sucks way to much power and even makes the vehicle jumping it start to bog down. Next I was going to get a new starter solenoid but don't want to keep throwing money at it in hopes it will fix the problem. Any ideas on what could be the problem?
