NO_SPRK
User & Abuser
So i blew up the 4spd in my 1991 crew cab. ive had a whole 1ton donor truck for awhile... waiting for the POS transmission to blow.
Besides converting to a 5spd im adding in the clutch master cylinder support brace and converting to hydro-boost brakes from a F450.
i noticed not many views so i thought if i remade a thread with the proper title people could use some of this info.
i was also lucky enough to have saved a set of drivelines from a 95 PSD ext cab long bed... the front section of the rear driveline is 8" longer
so i only need to shorten and balance it. re-sealing the T-case but trans was pretty clean.
AAA saving my butt.. F650.. cummins w/ allison
clean dual mass... Factory?
stock luk 11inch clutch w/ solid hub...
shes a little dirty but arnt they all
splines are in great shape but all clogged with burned clutch material
I would have saved the mat but as you see its already trashed
very very nice use of sealant there
