Farmer Rock
Good evening folks,Today I was doing an electric lift pump convervsion,and While I was looking for a good source of power to tap off of,I remembered someone telling me to use the FSS ,so I removed all three wires on the IP just to test them,and somehow the wire on the driver side furthest toward the rear of the pump,having no insulation shorted out on the side of the pump.Now two out of three wires on the IP have no power,and the truck won't crank at all.I later ran a wire from the battery to the starter relay and one wire on the IP,and it started right up so I know the relay works,and I tested all the fusible links and everything was fine with them,but I am really hoping I didn't mess up my ignition switch somehow,but I would assume the relay would be the first to go.I would really appreciate any and all help,I am nervous I really messed something up.thanks
Rock
Rock
