86, block heater question ,,
nhwrench01
new hampshire
I was looking for first hand experience with people who use there block heater on their 6.9.
my vin tag shows a build date of 12/85.
I have looked at the block area of the heater and it does have the deep milled space by the dip stick tube and ( what i think ) is the thicker casting around the block heater..
its been very cold in the N.E. and it would help alot with starting in the morning,, but not if the block cracks...
I know people will say just put a inline heater on it, but i like the thought of things working like they should,, but if i have to add a inline,,,,
and no, im not driving it everyday,, yet, just .
Thanks nhwernch01
KansasIDI
I hate printers
Wilsey, KS
Thanks nhwernch01
I wouldn’t be afraid of it, as long as it’s the thicker casting. I plug my 7.3 IDI in once it gets about -10* F (usually, but I’ve not done so the last couple times it was that cold)
What’s your engine serial number?
nhwrench01
new hampshire
hhhmmmm,, dont know the serial number... ill have to look..
Kevin 007
Full-floater
Nelson BC Canada
Without looking at the serial number, if you look at the dipstick tube near the block heater area, the casting is slight "raised" and curls around the dipstick tube, on the later thicker castings.
nhwrench01
new hampshire
ill look at that too,, thank you
nhwrench01
new hampshire
well, the block isnt cracked, but the heater is leaking some,,, sooooo,,,, looks like ill be changing that and doing the new radiator at the same time...
Kevin 007
Full-floater
Nelson BC Canada
That's a good block. Ya the heaters leak after time. Not a big deal to change, when the starter is out of the way. You might get some coolant down your arm, but life goes on
HammerDown
Glenolden Pa
Bummer... my block heater works but, if I use it the rubber O-Rings weeps coolant.
Oddly and thankfully it doesn't weep at all when the engine is running or sitting ... but only if I plug it in.
Guessing the o-ring has become brittle/compromised.
nhwrench01
new hampshire
nope, no big deal,,after all the work ive done on this thing so far,,, a block heater is not bad at all..
Bought it for a good price, ( for a running diesel in NH,) just some of the stuff but not limited too, front axle u joints, locking hubs,seals,calipers, used c6 transmission, deep pan,extra cooler, power steering pump,front drive shaft joints,2 batteries,starter, t" case seal,rear brakes( everything,and E cables), rear fuel tank, 2 sending units, 2 cab corners,rockers, floor pans, exhaust from manifolds back,,,,,,,,, with front fenders, radiator, and more to do,,,, i can handle this.... .. thanks for all the help.... great people here....
From what I can see in your picture, it looks like you have the later block. Mine quit working and it seeps from around the center bolt/screw a little bit. Since I also need to retorque my head studs and stop the leaking rear main seal, I'm going to wait until I have the engine pulled out in a few months. All one of the three can be done with the engine in the truck, but all three at once? No thanks! I'm pulling the engine.
Kevin 007
Full-floater
Nelson BC Canada
Is re-torquing head studs a thing? I re-torque every idi I touch that has bolts still, and never blown a head gasket with them, and they always take quite a bit to achieve spec, so im sold on the idea.. But I've always left the studs alone after they're installed.
I don't know except that these were from Justin and the instructions said to torque them to factory specs. They were at 100, but most say to pit them at 125 which I'm going to do before I install a turbo. Not that a first gen Banks will be much of a threat, but better safe than sorry.
Kevin 007
Full-floater
Nelson BC Canada
Good call. Yes I go to 125 on 1/2'' studs also. Just took a set of Gator studs to 125 an hr ago
Jt64
