'86 6.9 surges, rapid revving at light throttle?
dunk
Dunce
NJ
'86 6.9 turbo with 80k miles unknown age of fuel system components. Starts easy, runs smooth. Occasionally at light throttle like taking off from a traffic light it will rapidly rev up as if I gave it a lot of pedal. Really takes off and it's real touchy when giving it pedal, just a little and it revs real fast. Does not surge up/down or stutter, just takes off hard like I gave it a lot more pedal. Immediately returns to idle when I let go. It'll do this briefly and then go back to normal. I'd read a little air in the lines can cause surging but not sure if that would cause an up/down surging or a quick rapid revving like I'm getting. Did it for third time today and was around 1/4 tank. Last times were between 1/8 and 1/4 tank. After it did this it drove fine for about 5 miles, then I filled it and didn't do it any more. I've done the external vent mod on the front tank but have not pulled the sender/pickup. Rear tank doesn't take fuel so well, I have a 38 gal I'll be swapping in soon for that one and doing external vent and extending the pickup and removing showerhead/sock/whatever is in there.
Could this be a cracked pickup or showerhead getting ready to fail completely? Or would this be something else entirely? Please point me in the right direction, thanks!
Yes. What you posted tells us you have the classic broken off suction in the tanks. The front tank is simple to repair in the truck. No need to drop it. Just clean off the sender cover before removing it. Just 2 fuel lines and 1 electrical plug. then knock open the fastener ring and lift out the sender. Add about 3 inches of 3/8 hose and 1 hose clamp and your done. Make sure you feel the locating pin in the top seal of the tank lip or the sender wont fit correctly or tighten up correctly.
dunk
Dunce
NJ
Thanks. Sounds like an easy fix. I'm working on the larger rear tank today and will leave off the showerhead on the rear tank and just put a line to the bottom. Without any filtration on the pickup tube should I run a spin on or in line filter before the tank selector valve? Thinking if anything gets in the tank it could make the valve plug or hang without some sort of filtration before the main filter at the IP.
Several people have added a filter on each supply line between tank and selector valve.
It's a good idea.
Sent from my USCC-C6721 using Tapatalk
Cut a "V" in the bottom of your new pickup hose in case it gets stuck on the bottom of the tank.
dunk
Dunce
NJ
What's the best way to extend the lines for the larger rear tank? Seems like the people who have written this up use compression fittings and hard line as opposed to soldering. Any reason for that? For the front tank is a rubber line fine or is hard line preferred? The T on the bottom sounds like a good idea.
JunkCowboy
