84 6.9l idi wiring info help
idif250
50th state
I am recovering from too many P.O. alterations and have had trouble restoring the wiring harness. Any experience you have will help me save time, money and energy and I thank you in advance.
1) glow plug controller removed(original snapped off in block) switching to manual= which size gauge wire to relay from battery and from relay to glow plugs?
2) harness was melted in various spots: RED w Green stripe from cab to GP controller and injector pumpx2/tps/temp = should they be sepearate power supply and what voltage,gaugewire should they recieve?
3)Supply to injector pump is related to fuse panel in cab or ignition switch? where is good source for this?
I looked through forums and it has helped me plenty, seems when one component fails it can lead to additional failures when I have this all figured out i'll post. thanx again.
On some of the later trucks Ford used two #10 wires side by side to feed the glowplugs. Some feel this is too small and go with a even larger wire, but I would consider two number 10's minimum for that.
The red/green is key-on power. #14 should be big enough for all the original loads on this wire, Ford probably used a #16. Anything that was hooked to the red/green is on the same circuit. If it's a different circuit, it will be a different color wire.
The red/green was the supply for the injection pump, and it came directly from the ignition switch through a fusible link, no fuse on this wire.
bleachasaurus
Staff online
