7 blade trailer plug
kbenz
kannapolis, NC
I was looking up 7 blade wiring diagrams. I didn’t realize there were different variations of it. Is there an actual standard for it? Or most common at least
MadMac
SMF
Yes, apparently there is a standard SAE J2863. There are three minor revisions which are of no real consequence. There are four major seven connector plug types, of which what we all use... is the 7-Way RV Blade (Standard – SAE J2863 / SAE J1239).
I fished this out with ChatGPT, and a bit of other research:
Most common in North America (light-duty trucks, SUVs, travel trailers)
Flat, rectangular blades
Plug shape: Round body with flat blade pins
Female plug on vehicle, male on trailer
Pinout (clockwise from top center pin):
PinFunctionWire Color (typical)
1GroundWhite
2Tail / Marker LightsBrown
3Left Turn / BrakeYellow
4Battery Charge / +12VBlack
5Electric BrakesBlue
6Right Turn / BrakeGreen
7Reverse Lights / AuxPurple / Red
The others are:
2. 7-Way Round Pin (Commercial / Agricultural / Military)
• Round pins (not flat blades)
• Often found on semi trucks, farm equipment, military trailers
• Same 7 functions, but:
• Different pin shapes
• Different pin assignments (depending on usage)
• Not interchangeable with 7-blade RV sockets
3. 7-Way Flat Pin (Obsolete / Rare)
• Flat pins arranged linearly in a rectangle
• Occasionally used in older utility trailers or European conversions
• Mostly deprecated in favor of 7-blade or 6/4-pin connectors
4. ISO 1724 (European 7-pin Round)
• Common in Europe, not compatible with U.S. plugs
• Round with small round pins
• 12V system but with different function assignments
• Caution: Never assume plug compatibility between EU and U.S.
