7.3 swap
ranchero260
Flemington Pa
I have a chance to purchase a 1960 Ford F700 with a 360 gas motor. How hard would it be to transplant a 7.3 into it with a 6spd trans? IDI or power stroke?
u2slow
bilge rat
Coastal BC
IDI for me. I won't touch another powerstroke. ZF6 is problematic to swap behind an IDI.
edit: in that size truck, I would be looking at inline 6's instead. 5.9/8.3 Cummins; DT360/466 International, or 6.6/7.8L Ford.
Smitty 90idi
Army
California
The original motors at roughly the same HP and TQ numbers as an IDI. I’d never do a power stroke. The most power in the available engine line up came from the 302 Lincoln y block running 185hp and 270lbs of tq. The transmission’s had a very low 1st gear and were more heavy duty then the zf5 or 6. The t98 4speed had a 6.40 1st gear and the Clark’s went all the way down to 7:1 1st gear. The zf5 only goes to 5.7 and the zf6 gets down to 5.79. Not much difference in the 5 to the 6 other then picking up an extra gear in 2nd but then you have a bigger hole from 3rd to 4th. So it will come down to the axle gearing or a low range box to get things going if you haul heavy with it. The 7.3idi came out n heavy 700 class school buses in the early 1990s with a 4speed auto. They had very low rear ends.
u2slow
bilge rat
Coastal BC
I am leaning more to a 99-03 7.3 not IDI
Then I strongly recommend gutting a whole running truck (with the correct trans) so you have *everything* to start with.
And you further want to be good at electrical and HEUI troubleshooting for the problems that come with a 23+yo electronic diesel.
  • Like
Reactions: Clb
Grumpy bruce
Ca
I swapped 85 idi ,into a 1977 3/3 ton GMC. Stick with a Ford trany or you have to adapt the bell housing. Also you putting a 900 lb motor in there,so build up the frame,if it has leaf springs you may need to a stronger set . Brake change drum to rotor,might be ok with radiator if not you can last time I looked the copper ones were available steering upgrades . Took me about 40hrs back ten , chaseing parts ,cross member mods , mounting brackets, reverse pan and oil pickup to back wiring easy . Have fun.
bneumann22
