7.3 injector problems
thedieselkid
westva
my injectors stops working when engine warms up. i got rocker cover off when started cold oil is pumping out spout but after few minutes nothing. i checked the armature clearance and its .003". anyone know what up?? is it o rings or something more??
greenskeeper
PA
HPOP oil an inch from the top of the reservoir when it stalls out?
thedieselkid
westva
no. it doesnt stall out. has miss and shake.did a Cylinder contribution test showed misfire so i popped the rocker cover off but injector was spraying oil out spout. i let it run for 5 minutes and nothing coming out of oil spout. i expected poppet to be worn but its not .003".
greenskeeper
PA
So 1 injector out of the 8 stops leaking oil out of the spout after 5 minutes? The other 7 injectors keep leaking oil?
fraree
Inland. Australia
I can't find a thread on replacing injector sleeves, (have the sleeves from Rock A) so this was in the same area so here goes.
What seals will I need ? I've never had this apart before so just after some info. Doing the job at a mates workshop (Ex Cat & Cummins fitter) so can call for assistance with the sleeve removal tool.
fraree
Inland. Australia
Thanks, that video was "War & Peace" :rolleyes: not just the headlines, like it should have been. Just use thread locker around the cups & press in :Thumbs Up
fraree
Inland. Australia
Couldn't put this off any longer. Started the injector sleeve replacement job today. Searched multiple "youtube" videos on the subject, trying to remember all the odd bits to do as I've never been inside one of these engines. All good so far.
fraree
Inland. Australia
Radiator & intercooler out for a service. This side is not to bad to work on
