Justin Short
Hey Guys,
New to the forum. I have searched and searched but was not able to find anything that is like this particular case.
My truck is a 1990 (N/A) 7.3. It has since had a hypermax T4 turbo setup at some point in time. Not too long ago I replaced the IP and injectors (maybe 300 miles). At idle I get a terrible vibration that almost feels like a miss and it seems to increase with RPM as well. There is no blue smoke at anytime at any temperature. All compression checked out within 10 psi of each other as well.. I can loosen the injector cap lines and all seem to effect idle similarly. It also passed the clear line test. Would engine mounts be next to question???
Pyro: Never above 1100 degrees. And runs excellent when not at idle.. or under load.
P.S. I replaced the IP with Delphi and injectors were from Pensacola.
Thanks!
Thanks!
