So your truck is N/A at this point, correct?
Compression is even, but what are the numbers? Perhaps the reason it had a turbo at one point was to make up for a worn engine? How many miles on the truck/engine?
You cracked the lines to check the injectors, the question is, can you tell a dead miss from a weak hole when you have more than one at the same time? It takes a learned ear.
The next question is, are your injectors even all one type? What are the code stamps?
Did you clean the seats/bores when you replaced the injectors? Did you get the old washer out of EVERY hole and replace them?
Buy or build a pop tester and check them all out (and recheck the injector bores), it will probably cost you less than you just paid that shop to time your truck even if you buy one. Maybe you have a couple that are popping at different pressures or not atomizing properly.
Are your GPs seated properly?
Is this your only vehicle?
You really need to check the injectors now, who knows, maybe you only need one, maybe you need 2, but if you find some that aren't up to *****, that won't mean you have to replace them all.
Just remember, your injectors and IP are a 100k service item, fix it right at this point, and you'll have years before you have to do it again, and to be honest, if you re-time the truck, you can extend that period, not indefinitely, but some until you can afford to replace them again.
If you don't fix the issue, do you think you'll be happy with the truck for 10 years like this? Probably not. This isn't even bringing up the added vibrational stress on the trans, body mounts, engine mounts, hard lines, etc. from the rough running engine.
Fixed it for ya.
Make it 5 now
[/QUOTE]
This is not my only vehicle, one of many headaches..
The copper washer came out of every hole, glow plugs seem to be seated properly, 171k on the truck and if my memory recalls compression numbers were all like 350..?? All new injectors were from Pensacola and I believe they are bb codes.. They only sell 1 code now I believe. I think I got all of the questions
