sam shelly
Hello I'm having trouble figuring out why my truck won't stay running. It's a 93 f250 with the 7.3 IDI. One day I was driving and the fuel filter light came on and the truck stalled shortly after. It would start back up easily but only for a second then stalled again and again and had to have it towed. Only way to keep it running was to hold the pedal to the floor and the RPM still so low it wanted to stall.
So far I've replaced the fuel filter and and replaced the manual lift pump with an electric facet pump. I have a clear line running from the fuel pump to the filter housing and another clear line from the IP return to the injectors. Both lines appear to be full of fuel and not seeing any air but still having issues. Now the truck will idle longer but very rough and will stall after giving it throttle. Sometimes it still dies shortly after startup at idle, it's pretty random.
If I give it throttle the RPMs go up briefly then fall back down/surge and stall. I'm not very familiar with this engine and haven't been able to find this exact issue online, so was wondering if anyone has any ideas. Was thinking replacing the injectors or injector pump next but I'm really not sure
