For easy of assembly, I’d use the 6.9L lines that were already on the truck. They’re going to be closer to lined up with your injectors. I’ve had issues swapping 7.3L lines in the past because they were set up for engines with the weird timing adaptor that’s more common on vans. But all the lines are functionally the same and it won’t make a difference which engine they came from as long as they are capable of delivering fuel. Every diesel repair manual you will ever read says NOT to bend metal fuel lines. But from personal experience, if you’re only tweaking them slightly (not enough to distort their shape) you won’t run into any issues.Good evening,
The 6.9 IP is out and the 7.3 IP is in. Everything seems to be fitting in fine, except the injector lines seem to be a little off from where they need to line up. Would using the 6.9 lines be a better way to go about this? Or should I tweak the 7.3 ones to make them work? It’s only one or two that really need some tweaking but I am just wondering if the 6.9 lines would just be better in the long run? Please let me know on any input you have.
Thank you,
The return line? That should be a basic rubber hose that comes from the black caps/fuel lines that sit on top of the injectors and goes back to the fuel filter. I think you’re talking about the metal feed line that goes from the filter into the center of the injection pump? Honestly, every time I’ve done a pump I loosely install all the lines onto the pump, place it on the engine and get everything aligned, tighten by hand so they don’t move, take the pump back out and fully tighten, then reinstall on the engine. It’s tedious for sure. If you’re trying to do it on the engine then maybe a crows foot or a line socket might help. Although access might be really tight. As far that black thing goes, that is indeed a gasket. Unfortunately you will need to replace it or the hose will leak.I ended the day with the pump all hooked except the return line. I decided with the 7.3 injector lines as I already had them in with the pump and was able to tweak them into place.
I was wondering if anyone had tips on reconnecting the return fuel line? I have been adjusting the nozzle and tweaking the line for proper alignment but still struggled actually get the nut to thread. Is there a certain technique that will help with the process or is it just a matter for fiddling with it? Additionally, as I was messing with it a small black ring fell out of either the return line or nozzle broken in half. Is this an important gasket or washer that I should replace? or simply just some build up of something.
Thank you all for the support! Its been truly helpful.
Got it. I put a soft line on that with a fittings. One of the diesel distributors makes a kit. Gets ride of a lot of issues. Even makes timing easier.I will definitely try cutting some of my own olives. Thank you for the suggestion.
