Lanithomas
I recently swapped a used known working injection pump into my 92 7.3 idi static timed it and bled all of the lines it fired right up but ran terribly like it was getting too much fuel. Tried to retard and advance the pump to see if I could get it to run better but no luck I removed the injection line holders so I could get more movement to adjust the pump. Long story short it no longer starts. Is it common for injection lines to have holes where the holders are? Or what else could it be? I’m kind of at a loss with this truck. Tia
