7.3 idi coolant, cavitation questions
FoolhardyIDI
Arizona
There are plugs on the block that can be pulled to drain the system totally. One on the driver side next to the oil filter and one on the passenger side next to the starter. When I did my cooling system flush I refilled with Final Charge $12.50 gallon at Walmart I know Walmart sucks but they have the best price.
CDX825
filtration nut
Litchfield,Ohio
I mentioned pulling the block drains in my flush post:dunno
Anyway Final Charge is great coolant! If you flushed and refilled with Final charge you shouldn't have to worry about your cooling system for a long time.;Sweet
furfishgame
Pt Mackinzie,Alaska
Ha i should have posted this more than the night before i did it :p i didnt flush it out near that good. Only did one flush with distilled water.. Should i re do it?
stealth13777
Jacksonville, FL
I'd probably just run it. With new coolant you're already better than before. How dirty was it?
furfishgame
Pt Mackinzie,Alaska
The coolant was fairily clean compativly, how ever i found a couple small chunks (rather, flakes) of rubber in it, i know the previous owner changed hoses before i bought it and he said the old ines were pretty rotted.. Im assuming a coolant filter would take any particles like that out of the system?
