Okay, so teardowns always bring about the need for parts inspection, and my heads will going to the machine shop so for cleaning, inspection, new valve stem seals and new OEM valve springs, and whatever else the machinist may find needs to be done (hopefully not much as the engine only has 108K on it at this point). Just my quick, limited inspection shows that none of the pre-cups have any cracks
, cross hatching is still visible in all cylinders with no appreciable ring ridge, rockers all look good, etc. BUT, I did find a couple of things that may be of concern and would appreciate some feedback on. The end of the intake valve stem on No. 3 has some "roughness".
I looked at the corresponding rocker and it is fine - just a smooth shiny spot on it. I am thinking the valve was installed this way from the factory? Is it worth worrying about? I also found that No. 7 has way more carbon buildup on the underside of the head than any of the other cylinders. Leaking injector or something else? The injector is a newer Stanadyne from Russ that he installed a good used pintle in after I damaged it on install. (By the way, although I did the pintle damage, Russ helped me out and put the good used pintle in the injector and all I did was pay for shipping there and back - Thanks again Russ!)
Before teardown, I drained the coolant and put in tap water with 2 gallons of Restore Plus acid based coolant flush. I ran this in the engine for about 2 hours and then drained. I then put tap water back in and ran the truck for a couple of hours and drained and flushed and flushed some more. The cooling passages were nice and clean when I started working on this project, but the truck has now sat without coolant in it for two weeks and now it is all orange flash rust. Sigh, it just makes me sick looking at it. So now I am faced with using the Restore Plus again after I have the truck back together to get rid of the flash rust (read that as "using an acid based coolant flush on my nice new gaskets and oil cooler o-rings).
And speaking of the oil cooler, I haven't taken it out yet but the cooler pipe looks pretty bad - I will see how it cleans up with the sandblaster.
