19Eighty-Sixed
I have a two parter for y’all. First off, does anyone have the valve recession specifications for the 6.9L IDI and a source for that spec? I work at a Ford dealership but our system only goes back to 92 with a 7.3L. The WSM states that recession (for 7.3L) should be
.042-.054 intake
.051-.063 exhaust
But my machine shop said that on a 6.9L it should be
.042-.054 intake
.046-.056 exhaust
I’m willing to believe that they updated the recession spec, in the later years, for the 7.3L. But I’d like to know for sure if that’s the case. Google AI agrees with my machine shop but I don’t consider that a reliable source. So does anyone have an official source for what the spec on a 6.9L should be? That way I can confirm or deny what the machine shop says?
My other question: does anyone have any official piston-to-valve clearance specs? The WSM does not have that info and neither does the machine shop. I’ve read a bunch of forums on here (posted below) but there is not an agreed upon “correct” clearance. I’m putting a Logger Cam into my 6.9L so relying solely on correct piston protrusion and valve recession does not inspire total confidence. I’d like to cover all bases and verify that there won’t be any interference issues. I know Russ says that it’s a drop in cam but I want to ensure there’s no valve slap.
www.oilburners.net
www.oilburners.net
www.oilburners.net
.042-.054 intake
.051-.063 exhaust
.042-.054 intake
.046-.056 exhaust
7.3/6.9 IDI Piston to Valve Clearance Spec
Wanted to document this here in a dedicated thread for others to reference as I had to dig for it through many pages on others. I just finished using Play-Doh to verify my piston the Valve clearance and wanted to know what is an acceptable value. According to Russ Mathis (RIP), whose word I...
Cam Upgrade to 7.3idi NA diesel
I sink the valves to .060 in the heads. .040 is the minimum number of clearance.
7.3 IDI Turbo Knock -> Engine Pull and Rebuild
So , for all practical purposes, that's zero expansion. Thanks Wes! You can buy adjustable pushrods. I'd bet that Summit racing would have them, among others. Maybe these are the ones that Wes was talking about since he has a background in racing engines. Yes. I did forget to mention it in my...
