adamsanders
OLDBULL8, the first pump did run well but would not start after it was hot. Seeing as how this seems to be a top symptom of needing a new IP, I went and bought a cheap pump of craiglist as a gamble. When I installed this one, the truck ran very rough and had no power. I wanted to advance timing just to see. I put a rag lightly in the glowplug hole and when I rotated the engine one rotation blew the rag out and the other did not. So I know I was at TDC in compression. I then rotated the gear one tooth but it helped the pump none.
