1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
6.9l best place for injectors?
Discussion in '6.9L IH & 7.3L IDI Diesels' started by Cainon, Jan 21, 2020.
  1. Cainon
    Cainon Full Access Member
    87
    22
    Sep 27, 2019
    Smithfield
    Has been knocking now a few days. Sounds like a rod bearing but everything I read says injectors. Is this common?
  2. Oledirtypearl86
    Oledirtypearl86 Full Access Member
    34
    1,226
    587
    Sep 17, 2018
    Whitehall MT
    Could be fuel knock if your looking for injectors get ahold of Wes aka @Thewespaul
    Frstdiesel, Trevtron and Cainon like this.
  3. Randy Bush
    Randy Bush Full Access Member
    481
    289
    Jan 2, 2019
    Great Falls, Mt
    Crack the lines to see which one is bad , then if really want to move to a different cyl to see if the noise follows.
    Cainon likes this.
  4. Cainon
    87
    22
    Sep 27, 2019
    Smithfield
  5. Cainon
    87
    22
    Sep 27, 2019
    Smithfield
  6. Cainon
    87
    22
    Sep 27, 2019
    Smithfield
    This is the best I could record the noise. Sorry for the quality. 0-60 phone is sitting on the dashboard
  7. hesutton
    hesutton The Anti-Anderson Supporting Member
    44
    8,112
    647
    Aug 19, 2005
    Bowling Green, KY
    Injector body and fuel line will typically be very hot if it is sticking open allowing exhaust gases backing to the injector causing a knock. Can even melt the return line cap.
    I've had nothing but excellent results from Conestoga Diesel Injection.
    Heath
    Cainon likes this.
  8. Randy Bush
    481
    289
    Jan 2, 2019
    Great Falls, Mt
    A bad injector sticking open will also cause pressure built up in fuel tank.
  9. lotzagoodstuff
    lotzagoodstuff Supporting Member Supporting Member
    2,185
    172
    May 19, 2007
    Maple Valley, WA
    Russ, aka Type4, is also a good source for new injectors, he’s in Oregon, south of Portland.
  10. Cainon
    87
    22
    Sep 27, 2019
    Smithfield
    So this would be why my gas cap is so tight. Thank you
    Randy Bush likes this.
  11. Thewespaul
    Thewespaul Supporting Vendor Supporting Member
    8,288
    6,789
    Jul 27, 2015
    Bulverde, Texas
    I’ve got injectors in stock ready to ship classicdieseldesigns.com, no core charge.
  12. Trevtron
    Trevtron Supporting Member Supporting Member
    44
    251
    119
    Aug 18, 2016
    Katy, Texas
    Injectors I got from Wes have been hammering away flawlessly for good while now, I highly recommend his injectors.
    After I put them in and timed the truck it began starting within the first bump of the starter, he built them right
Share This Page
