Ya imma pressure test it there and probably change the ficm with my buddy’s just to see if that’s it. Will on 03 ficm work?
I just had a chance to watch the vids. I noticed that your supply voltage to the FICM was low. Even though the FICM is outputting 48v, that low input can cause issues. Plus the 48v may not be to all injectors.
The buzz and balance will tell a bit more.
Though a truck can fail a buzz and even fail a balance and run ok, depending on a few factors.
An example of this is a truck I have in my shop now. Fails the buzz on number 2 and 4 injectors. Shows a cylinder a contribution code on number 2 cylinder. Power balance shows one cylinder (cyl 2) as being low. However if I move the injectors around and put the two offending injectors in different holes, then they still fail the buzz but the cylinder contribution goes away and the power balance is in acceptable range.
Another truck was exactly the same except the cylinder contribution still showed (moved with one of the injectors) but the truck ran well.
The 03 FICM should start and run the truck for testing.
But The low supply voltage is still a small concern.
