Rodm
Hi, to all. New to your site and a bit run down fighting pneumonia. I have been trying to finish a complete flush of my 2000 7.3 Excursion 2 x 2 using Mark Kavolsky's method. The pan was drained, dropped and filter changed. Torque converter had no drain. Over the course of the vehicle sitting almost3 weeks 10 quarts drained out. I added 6 quarts Mercon V to the filler tube started the truck with hose attached at transmission return line however the flow to the catch container is almost non existent. I was able to catch maybe 2 quarts when the engine was first started but then the stream died while running through gears. How long should I run the engine for in park before going through gears and how long to wait for pressure to build up. I really dont want to burn my tranny up.
THANKS A BUNCH Rodm
THANKS A BUNCH Rodm
