Was A/C available from the factory with the 37" radiator? Im trying to locate belts and hoses and all I can find is for 31" w/ A/C. I have the 37" and A/C. Trying to find the belts is impossible do to all the different options. Ive never seen the routing of the belts installed, as they were removed when I got the truck. Does anyone have pics of belt routing?
The belts I got with the truck is Motorcraft JB-332, JC-564-LA, and two dayco 17675GL. I would think the daycos go on the crank, fan/water pump and Alt. The JB-332 goes crank and vacuum pump and the JC-564-LA possibly water pump, power steering and A/C? Im not sure. I was able to cross the 332 and 564 to gates numbers, but gates and rock auto can't find the dayco #.
Does anybody else have the same setup? Im thinking the A/C must be a dealer installed option, it is a motor craft A/C compressor. Im lost.
