Ricky Vickers
so i have a 95 ford f150 with a wore out 302 i plan on swapping the axles and then swapping into it a 7.3idi non turbo. i was just looking for some advice on the swap anything would be appreciated!!
I would find a coil dana I think it came in 02 or 04 can't remember. Would make it better on flex
Sent from my SAMSUNG-SM-G870A using Tapatalk
They make a Kit that you weld/bolt on and the Dana 60 bolts right in place and where the truck is already ttb the Dana 50 ttb will bolt right in And the whole purpose is a 3/4 ton ext cab shortbed idi
