1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
3 phase converters
Discussion in 'Lounge' started by Thewespaul, Oct 9, 2019.
  1. Thewespaul
    Thewespaul Supporting Vendor Supporting Member
    8,259
    6,744
    Jul 27, 2015
    Bulverde, Texas
    I run a 3 phase converter to run my 5hp Bacharach test stand since I don’t have 3p going out to where it’s setup right now. Well Sunday night the converter cooked itself pretty good and ate up some of the wiring. I’ve got it back up and running on my generator, but I would like to replace the converter with a quality unit that will support my larger stands if necessary. Open to some suggestions, I don’t have a lot of experience with converters so hoping the collective can point me in the right direction, thanks y’all!
  2. DaveBen
    DaveBen Supporting Member Supporting Member
    71
    1,492
    336
    Sep 29, 2010
    Ukiah, Ca
  3. Oledirtypearl86
    Oledirtypearl86 Full Access Member
    34
    1,219
    584
    Sep 17, 2018
    Whitehall MT
    My dad is an electrical engineere he said the converters have come light years in the past few years but all iv ever used was a rotary inverter for our compressor to fill air tanks
  4. PROFG
    PROFG Full Access Member
    139
    32
    Aug 14, 2019
    SE CT
    Advantage of modern digital 3 phase converter, up to 10 hp, is fit in a lunchbox, input 240v ac OR dc, speed control, current limiting, full torque @ low rpm, etc. Often find a 3 phase motor and speed control for less than same HP single phase/single speed.
    A typical 4-kW rotary has a fairly constant 500-W of parasitic losses (windage, bearing losses,iron losses, and copper losses). So at full power - supplying a 4-kW load, it is 89% efficient. Clearly as load falls off this efficiency figure worsens, e.g. to 80% for a 2-kW load, and 67% for a 1-kW load
    DaveBen likes this.
  5. IDIoit
    IDIoit MachinistFabricator Supporting Member
    12,548
    2,231
    I run my entire shop on a phase converter.
    if youre looking for a VFD, I have one forsale
  6. IDIoit
    12,548
    2,231
    pics of the VFD, never been used.
  7. PROFG
    139
    32
    Aug 14, 2019
    SE CT
    Have one, 5hp, used on electric roto tiller for a test. Don't run over the cord (DAMHIK).
Share This Page
