My truck is a '90 and everything I've read says that the fuel return lines should be 1/4" 7mm but the lines on there are 3/16" 5mm. Did some 7.3s, maybe early IDK, come with the small lines? Should I swap out to the 1/4" when I put the new pump in?
It could have been a roadside repair and that’s all the parts store had, I would replace it with the injectors. I believe Mel includes his return kit with every set of injectors
