2wd + rsk
Greg5OH
MI
With an RSK kit, does the front frame still have to be extended to mount a D60 under a 2wd truck?
Im assuming frame should still be reinforced. Can this be done with engine still in? What has to come off-front end support?
lindstromjd
Black Sheep
West Des Moines, IA
From what I understand, the front of the frame is extended a little and boxed in to reinforce it with the RSK. The radiator support gets the rivets drilled out and lifted up a little to give you working room. No need to remove the engine or do any other serious work to the truck aside from installing the kit and axle.
I don't know why you would need to modify, strengthen the front of the frame with a RSK kit. If you look at the kit you get from Sky Manufacturing, they sell you a custom front crossmember in the kit to mount the leaf springs. I would think that would give you plenty of strength, probably more than a stock 4x4 frame has.
Greg5OH
MI
franklin, i dont see anything for pre 92? I got a 91 and this is where I was afraid things get trickier than with an OBS style.
Turbo, yes im up in pontiac/auburn hills area.
JunkCowboy
