1996 (OBS) problems
Csklar1967
Nashville, TN
Hey all,
I’m new to this blog and new to owning a diesel truck. I bought this truck private party a little over a month ago. It ran great until the last few weeks. It has a tune, 4 inch straight pipe and intake. There’s a few things wrong with it, at idol it intermittently dies but starts right back up. The battery light comes on or flickers intermittently. While driving two other things occur, under load at lower RPMs, it sputters and loses power. It also cuts out intermediately, like I lose accelerator control, if I push the clutch in and coast, it does fire back up on its own. batteries, alternator, and charging system seem to be fine. I recently did an oil and filter change along with the fuel filter. I suspect it could be a lot of different things. Just not sure where to start. It’s a 1996 four-wheel-drive with a 5 speed manual transmission has a little under 250,000 miles on it. The tune is a Power Hungry performance Hydra. Any ideas of what can be happening would be appreciated. Thanks!
u2slow
bilge rat
Coastal BC
Two best troubleshooting things I found...
1) mechanical lube oil pressure gauge
2) mechanical gauge on the hpop output (0 to 2500-3500). plumb it into a cyl head rail.
Black dawg
USA
Most every 7.3 powerstroke quit but restarts that I have dealt with was caused by whatever was plugged into the ecm, or that connection not being clean enough.
Do you have a way to watch datastream?
Smitty 90idi
Army
California
sounds electrical. Grounds? cable corrosion? How do you know the alternator is working? Plugs and connectors?
Purple obs
pa
^^^^^^^^ I second this. Check the tuner/chip connection to the ecm. Remove it and try that, just know your truck will be rather sleepy without it...
Csklar1967
Nashville, TN
I think it’s electrical as well, but I metered out both batteries and checked the alternator output with the A/C and lights on. Don’t see any physical corrosion or loose connections. The tune is a possibility as well. The numbers on the tune selector were displaying a bit weird, also very intermittent. I really only saw that happen once, hasn’t happened since.
Csklar1967
Nashville, TN
I don’t, and I believe the ecm is buried behind the parking brake pedal, following the ribbon cable. I don’t think my year has an OBD to plug into. I wish I was able to do that, of course it would be a lot easier to troubleshoot.
Purple obs
pa
There is 3, 13mm nuts holding the parking brake pedal to the cab. Unbolt it and it folds in, giving decent access to the rear of the ecm.
u2slow
bilge rat
Coastal BC
My memory is fuzzy on the F-series locations, but theres the PCM and the IDM (2 separate computers). On the E-series IDM is under the hood by the hinge and prone to getting soaked by rain.
bneumann22
