I agree on U-Joints also. I know someone that had a Bricknose F-350. It had all kinds of weird steering issues. Would pull, would jerk, had trouble turning the wheel, or could make a turn and it would not self-center, it would stay "stuck" in the direction of the turn and he would have to strongarm it back straight.
He replaced all the "usual suspects" ball joints/kingpins (not sure which it had), Tie Rod Ends, bushings, steering box, dampener... still had the same problem. He took it to another shop and they started looking into it, and found one of the knuckle U-Joints had 1 axis that was seized. Not both, so one set of cups turned freely on the "X", the other set would barely move on the "X".
How this happens is during normal 2 wheel driving, hubs unlocked, the front driveline will still "freewheel" a bit, and the shafts will move around some. So at times, the stuck joint was in a position that movement of the stuck set was not necessary and everything worked as it should. Later, after things have moved around a bit, now this stuck axis is the one that needs to move... and it doesn't move well at all, causing issues. Later, its moved more and the bad set is back "out of the way" again......
I would say check out the U-Joints in the front axle, inside both knuckles behind the wheels.
