1993 F250 Super Cab 4x4 - 7.3 Turbo - Auto - $4500
93IDIT
The Dalles, OR
1993 F250 Super Cab 4x4 - 7.3 Turbo - Auto - $4000 OBO
1993 Ford F250 Super Cab, 7.3 IDI Turbo, Auto trans., 4x4
Reasonable offers considered. Willing to work with shipping, maybe delivery to NW states.
Dual tanks
Tilt wheel, cruise control
093 ATS Turbo - 3 inch high flow downpipe, 3 inch exhaust
Purchased February 2012 – 268,000 miles
Currently 285,500 miles
More Photos: https://www.dropbox.com/sh/5khzqyet97oe6j0/AACpFd5P6_ZkEHOiO-guXHfAa?dl=0
Maintenance:
March 2012 - brake hoses F & R, master cylinder, brake booster, serpentine belt, radiator cap, shocks F & R, injectors (BB code STANDARD MOTOR PRODUCTS FJ258 reman)
July 2012 - power steering pump, ps hoses, ps gearbox, rear brake pads, cylinders, hardware, axle seals, front springs and poly bushings, axle pivot bushing, center link, front end alignment
August 2012 - headlights, side marker lights, taillights
April 2014 - manual locking hubs, spindle nuts
The bad stuff:
Rear tank sucks air so only front tank is useable. I pulled the sending unit/pickup and found a broken pickup. I replaced it with a section of hose and fished out all the broken parts. The connection between the hose and metal tube at the sending unit feels loose. It might need a new o-ring. It could also be the tank selector valve.
Cruise control is not smooth. Speedometer is not stable at speed. Axle speed sensor needs replaced.
Batteries are weak. They will not start the truck when temp drops below freezing.
pwillis
