1993 F250 7.3 4X4 ZF5
danman004
IL
For sale 1993 F250 4 wheel drive 5 speed manual ext cab 8ft box. 215,***. miles and changing. Tons of mechanical work in the past 5000 miles and less. 2 new batts, upper and lower ball joints (both sides) all tie rods. brake lines and clutch line. new brakes all around, New clutch and master cylinder. Trans rebuilt. New fluid in both diffs and transfercase. Rear end rebuilt with new spider gears. rad flush with new upper and lower hoses. both fuel tanks replaced ( senders and shower heads were still good tanks just leaked), replaced almost complete exhaust, new shocks all around (KYB), all font and rear drive shaft u joints replaced, All 3 front axel u-joints replaced(center one broke so replaced all 3 at same time) seat was recovered comes with bed mat, headache rack with 2 lights and 2 smaller tool boxes they have some holes drilled in them but can be patched
im sure im missing a few things
comes with 8 ft westen pro plow. in good working condition.
Truck hasnt been plowed with very much only family homes and one small paring lot.
Has some rust on bed and front fenders.
NEEDS
I think the tank selector valve is starting to stick it is intermitant
have the 4x4 shifter but the linkage is for an auto trans so needs to be shortened but is all there and working( original one was broken when i bout the truck so i got another) i have just been climbing under to put in to 4x4
Hard starts in the cold if not plugged in. when plugged in starts with no problem i believe it is just the GP controler i have not had time to dive into it.
asking $4000.00 OBO
i have a ton of money into making this truck reliable.
located 35 miles west of Chicago
call/ text/or email
Dan
630-742-7399
danman004
IL
TTT any interest....Open to offers.....i bought another truck need this one gone!
pwillis
