7IdIguy3
Hello this is my first post on here and I’m hoping someone will be able to help me out. I have this knock that appeared when the timing gear housing seal was replaced and the pump gear was advanced by one tooth. After a long tedious task of getting the front of the motor removed to see the timing gears showed my timing was off. I reset the timing to top dead center aligned the pump gear to the cam gear Y to Y and put it all back together. The truck starts up and runs really good but when you give it fuel it has Delayed knock or ping I’ll try and add a video of the sound but I’m not sure what it could be. All injectors have been replaced too. Thanks for taking the time to read my troubles
