madpogue
No. CCSBs are F250s.
All the ones I've ever seen are. All the F250 around here are super cabs or regular cabs.all crew cabs are F350, no?
D50s are good axles if you don't mind taking 40 acres to make a U turn is a non-issue to you.
Dana 50 good thing> axle shafts and Ujoints are external full clip, and not internal C clips like a 60. so they will take more shock loads for heavy service.
Axle type is based on model, not cab type. OP said F350, so it's a 60 (oh, yeah, he bought... well... stole it; see his other thread).
that all went out the window in 1992. ford pared down the choices to D50 or D60 depending on the GVW.All f250 extended cabs are dana 50 ttb. Regular cabs are all dana 44hd ttb unless special ordered dana 50. It all has to do with the GVWR of the truck as to what the factory installed. Extended cab trucks have a higher GVWR.
