093 Wastegate adjustment?
Discussion in '6.9L IH & 7.3L IDI Diesels' started by saburai, Oct 12, 2017.
  1. saburai
    saburai Full Access Member
    505
    78
    Mar 15, 2016
    Bokeelia Florida
    Howdy folks! Well the turbo is in and old Diego is much improved. At wot, it's making about 7-8# of boost. If I adjusted the wastegate rod would I see more boost or a quicker spool? I've got got the fuel turned up about a flat and a half and next week I'll be paying a visit to Corey to make sure that the timing is where it should be.
    BTW if I keep my foot in it, the EGT's would, I think continue to rise past 1100*. I've got absolutely no desire to cook or break anything, this truck need to be dependable before all else...
  2. Clb
    Clb Another old truck Supporting Member
    2,960
    117
    Mar 1, 2013
    napa
    Yes you can get more boost ...spool is unknown(by me)
    Yes egt's can go to high, more fuel make it worse ..more air makes it less...
    Search drilling out the dimples on the rod
    DO NOT ADJUST IT TILL YOU READ THIS
    My 093, in my sig line w/stock pump (unknown fuel screw setting) will just hit 11.5-12# and 1000-1100*
    I would tune it to 10# and 1000* for foolproof driving till you know what more you can get away with...
    Ymmv
    Just my .02
    saburai likes this.
  3. saburai
    505
    78
    Mar 15, 2016
    Bokeelia Florida
    Thanks friend! Some research to do after the sun goes down.
  4. Thewespaul
    Thewespaul Supporting Member Supporting Member
    1,415
    352
    Jul 27, 2015
    bulverde texas
    I would set timing them adjust the wastegate, my guess is that’s the cause of the high egts and low boost number
    saburai likes this.
  5. Thewespaul
    1,415
    352
    Jul 27, 2015
    bulverde texas
    Double and triple check for exhaust leaks as well
  6. saburai
    505
    78
    Mar 15, 2016
    Bokeelia Florida
    Thanks Gents! I'll wait until after it's timed to adjust the wastegate. I've got a mandatory road trip this weekend, about three and a half hours each way, not pulling the trailer and not in a rush. What's a (very) safe cruising exhaust temperature?
  7. Clb
    2,960
    117
    Mar 1, 2013
    napa
    Lower the better, I cruze 5th at 65 ish around 6-800???
    I only pay attention when loaded.
    But mine will not break 1100 wfo
  8. Thewespaul
    1,415
    352
    Jul 27, 2015
    bulverde texas
    You’re not hurting anything under 1200 but the higher your egt the more your cooling system has to work
Share This Page
