junk
I'm trying to separate this up pipe on an ATS 093 turbo system. Any suggestions on how to separate these without breaking them? I currently have it soaking in PB blaster. Also is it typical to be able to remove and install this still connected when the engines in the truck?
Funny anyway... I use the aerokroil in my shop all the time. At this time kano labs is doing a twofer deal. Order one or two cans. Mix or match. Try one if you don't like it sent back the unused can and keep the open can... You will never send back a can. It just works that well. Add some heat and cool the stuck bolt with this stuff and its loose in no time. The machine shop I retired from bought it in the 55 galon drums because the so cali county felt the propelant was harmfull to the air. So we got in in the bulk size... We could not even use weed killer in the concrete lay down pads where the weeds grow between the cracks.. WTH is that all about... We even had to do a inspection every morning of all the floor drains to make sure nothing was in them but clean water. I found a white milky material one morning in one and we had all kinds of investigation going on as to what it was. Turns out some fool wanted the office floors waxed and looking shiny and some nite floor shiner poured out the stripper in the lot drain. Big deal over nother.. But someone had a job because of that mess.. Nothing but red tape investigation and someone finally had something to do for the high pay they got..
