divemaster5734
Putting an ATS 088 turbo that was previously on a '89 7.3 on a '90 7.3.
It's been sitting for over a decade, and sent it to CDD for a rebuild.
Got the turbo and exhaust all bolted up just fine.
I'm not seeing how to mount the ATS air filter, and not sure if there's a missing snorkel to pull fresh air in from a corner of the engine bay.
The 088 diagram I downloaded shows a stud supporting the entire air box, but the drawing depicts a square one, and mine is a rectangle.
I took a couple pictures with a tool holding it on place that I'll attach.
I'm wondering if I should just fab up a COI and stick a filter on that.
I'd have to provide a 3/4" hole for the crank case breather off a catch can I added to delete the CDR.
This is a mock up of the full air box.
Here's just the base.
I was thinking I could possibly make a bracket that mounts off the front of the intake, but there's not much room for it on that throttle bracket.
I wouldn't know what size tubing or filter to get to eliminate the ATS box.
Hoping someone has seen this type of 088 set up.
Thanks
Thanks
