1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
05 No FICM Logic or Main power
Discussion in '6.0L Powerstroke Diesels' started by Ford428CJ, Feb 19, 2018.
  1. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    Klamath Falls, Oregon
    Ok here it goes. I changed out a HPOP in this thing. Put it all back together. Now I lost Main and Logic power to the FICM. I checked the Fuses. Those seam to be fine.
    I went to the FICM relay. Pin 1 and 5 have power (12.6v) all the time. Pin 2 I assume is a switched ground to trigger the relay!? I have nothing on Pin 2. The relay works as advertised and checked it. Any help would be appreciated ! Thanks
  2. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    [​IMG]
  3. 79jasper
    79jasper Chickenhawk
    26
    16,050
    1,304
    Oct 13, 2012
    I've seen this problem pop up in the forums. Can't currently remember the common offender.
    Ford428CJ likes this.
  4. Dsl_Dog_Treat
    Dsl_Dog_Treat I lost my face to the jaws of a poodle Staff Member
    47
    7,171
    120
    Jan 13, 2005
    Decatur,MI
    Harness connectors seated properly?
    Harness ground wire connected?
    Iirc pins 1,2,3,22&26 are all internal grounds and shouldn't pop a code.
    bismic1 likes this.
  5. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    Yes Sir. The harness is seated properly and I pulled it again to make sure no bent pins. And reseated again. The harness ground wire is connected in the back told the intake manifold.
  6. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    No codes popped
  7. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    [​IMG]
    [​IMG]
    So I assume Pin 2 on the FICM relay goes to that?
  8. Dsl_Dog_Treat
    47
    7,171
    120
    Jan 13, 2005
    Decatur,MI
    Here's the pinout for the ficm if you don't have it yet.
    I'd say for shitzngiggles to unplug the fan clutch harness but no code popped for a fault.
    Beginning to think your harness may be at fault since you have power in and out of the relay.
    bismic1 likes this.
  9. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    I have the power at the relay. I used my snap on test light and checked all the grounds at the plug to the FICM. They are dead!
    Thanks for the Diagram
  10. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    I even swapped FICM with a well known one that works. Nothing! Dead as a nail!
  11. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    I even unplugged the fan clutch
  12. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    Well... Got a game plan..... The back grounding wire ties all those grounds together. I assume the junction of where they all meet would be at the base of the 3X plug. I’ll have to trace it and see where the break is at.
    Sent from my iPhone using Tapatalk Pro
  13. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    [​IMG]
    [​IMG]
    [​IMG]
    Found the problems and fixed them! She runs
  14. Dsl_Dog_Treat
    47
    7,171
    120
    Jan 13, 2005
    Decatur,MI
    Good find!
  15. Ford428CJ
    Ford428CJ FE Freak!
    205
    6
    Nov 17, 2007
    Someone was tough on this ole 6.0. Lucky I have a over head creeper. And happen to look under the anti lock Break motor.... And noticed the cannon plug wasn’t seated....
Share This Page
