So I have a 1992 7.3 idi N/A and I removed the fuel filter vacuum sensor and installed an oil filled 0-15psi guage. I have a racor electric fuel pump and with key on engine of I have 6 psi of fuel pressure. With engine idling I have 0 psi.
Is the port for the vacuum guage a good spot to to measure post fuel filter pressures? I want to be able to see what pressure my injection pump is truly getting
