Lower steering shaft repair/ replace
m67tang
lawrenceburg IN
been looking at why my steering feels loose. I’ve found the lower shaft is loose. Also called intermediate shaft. Online the dorman part costs $230+. Is rather find another way.
Is there any other options to fix this??
1997 PSD F250
Well... there's several joints. Which spot specifically?
The rag joint? The slip joint? What?
Borgeson makes a nice one.
Not anything there to make it loose. Just a passthrough boot for the firewall. But above that is a ujoint.
m67tang
lawrenceburg IN
Can the upper u joint wear out? I’m thinking about pulling it later today after work and then maybe it’ll be obvious whatever is wrong
I reckon it could.
Yeah, have someone turn the wheel back and forth, while you look at every joint.
m67tang
lawrenceburg IN
As I watched the shaft, outside the firewall, it was as if it had a small orbital wobble, not just rotation in place. Seemed to originaate at the firewall. I don’t know how else to describe it.
m67tang
lawrenceburg IN
It’s off the truck now. The only looseness is where it’s telescope slide. The outer slide has a solid 1/8” slop, so that it orbits in the middle. Is that enough to cause loose feeling steering wheel.?
Rag joint is ok. U joint is ok.
m67tang
lawrenceburg IN
An Update:
I’ve purchased a replacement Borgeson steering shaft. Problem seems solved. Steering feels solid again.
Jake60
New Jersey
Mine broke the flat spring in the collapsible shaft. I have the Borgeson replacement, got it fitted in today except for the part where they have you file a new flat for the retaining bolt on the steering box shaft and not use the flat already there.
This is to maintain a mechanical lock since the factory flat is ground to the end? How critical is this I mean it seems unlikely that it's gonna slip UP?
William88
