What oil do you use?
FordGuy100
Silverton, OR
What's RP? What synthetic trans oil is out there that is not sulfur based (for the sake of the bronze components in my ZF-5 shooter). To answer the question, I use Shell Rotella T 15w-40, and Lucas oil stabilizer (going to Rotella T Synthetic 5w-40, and in the boxes)
RP is royal purple, synthetic oil
wilsondoctor
Doctor
Carlsbad, NM
8800 Lubrication Engineers oil. Non synthetic. Used for over 20 years in Alaska, Utah, Colorado amd Maine. My current Ram cummins has over 280,000 and runs great, with 12, 000 miles oil change.
JL
idiabuse
Princeton Fl
Engine= 7.3 Banks Turbo 6,500 miles all new, AMSOIL 5W30 Lifetime fill
Transmission= C-6 all trick parts AMSOIL ATF 100,000 drain intervals
Gear Vendors= AMSOIL MTL 5W30 30,000 mile change interval
10.25 rear dif= AMSOIL 75W90 Lifetime fill
Just took 6,200 mile used engine oil analysis report available in a few days.
Still pulling 22MPG ;Really
Javier
OkieTruckerD
A Diesel Nut
Harrah, OK
I use Rotella T 5w-40 in my crankcase, b&m synthetic trick shift in my 5 speed, and my p/s pump, my rear axle isn't synthetic yet, but currently has Lucas 85w-140 in it.
chris142
SoCal
What ever 15w40 is on sale. Lots of Warren oils like super tech and proline as I can get those cheap. I have ran Delvac,Delo too...when on sale. I don't think you can buy a bad diesel oil. I tried a 5w40 synthetic and my engine drank it like it was free.
Kiwif150
Waimate New Zealand
I use Sinopec 15/40 SM/CF Grade in most of the older diesels that come through the shop ...... wholesale price of about $430.00 usd for a 44 gal drum makes it one of the cheaper oils out there which pleases the hell out of my customers :):)
Oreilly has chevron delo xsp 5w-40 on sale. $22/gal, then through Chevron you can get a $20 rebate if you buy 3.
Sent from my SAMSUNG-SM-G930A using Tapatalk
