Air cleaner gaskets..7.3
tnmike55
NE TN
I need the gasket/washer that goes under the air cleaner bolt and the big washer that fits in a groove on the bottom of the air cleaner and seals the air cleaner to the manifold.
Any suggestions?
nostrokes
Colorado
Saw it somewhere on here a member was using a Chevy carb gasket.. wish I could remember who.. and what one...
tnmike55
NE TN
I think a Fel Pro 60038 will work for the intake. I might have to use a piece of inner tube and a washer on top.
plywood
Recovered N/A
Portland Oregon
Small block Chevy sounds kinda right but I remember a certain year Dodge 5.2l works. Dang memory. Trying to find somewhere I wrote it down but that stuff may have been in an old computer.
pelky350
Springfield, OR
For non turbo the chevy gasket works just fine I used one before. I can't remember the year model to use though somebody told me it on here. With a turbo however the chevy gasket kinda seeped oil some but still sealed for the most part but I did try re using it is possibly why
I recall this "chevy gasket" is from the 4 barrel Quadrajet carbs. Some good advice given here on this gasket too.
